BS EN ISO 13916:1997 (Welding - guidance on the measurement of preheating temperature, interpass temperature and preheat maintenance temperature).
The important bits are:
Interpass temperature definition: The temperature in a multi run weld and adjacent parent material immediatley prior to the application of the next run. It is normally expressed as a maximum temperature.
Point of measurement: Interpass temperature shall be measured on the weld metal or the immediately adjacent parent metal.
Time of measurement: Interpass temperature shall be measured in the weld area immediately before passage of the arc.
Hope this is useful.
