Up Topic Welding Industry / General Welding Discussion / Pipe weights
- - By THANATOS (*) Date 07-21-2004 01:57
Does anyone have an equation for figuring pipe weights? I don't have such a thing or any charts that would help. I would appricieate any help!
Parent - By thirdeye (***) Date 07-21-2004 02:40
Try these out. One is SI and the other is US.
http://www.extolohio.com/DATA/METRIC/metric_steel_pipe_data.html
http://www.pipemarkers.com/pipe-data.html
Parent - By thcqci (***) Date 07-21-2004 13:36
If you go to Google and put in steel pipe weight you will get a bunch of hits. On interesting site that briefly explains the dimensions of pipe is http://www.chilipepperapp.com/pipe_weights_dimensions.htm .
Found this also http://www.metalical.com/index.htm .
I made a calculator in Excel for our clerk who has to occasionally calculate weights for projects.
Parent - By THANATOS (*) Date 07-28-2004 23:33
I just wanted to thank you guys for the information! It really helped!
Parent - By jerryfry Date 08-11-2004 15:26
calculation for weight per foot of pipe.
dia.minus- W.T. x times W.T. X times 10.68 it will get tht weight evertime. Jerry
