Up Topic Welding Industry / Technical Discussions / WPS for P-8 to P-8
- - By vonash (**) Date 07-22-2004 00:12
Do I have to re-qualify my WPS for P-8 to P-8?
We qualified our WPS with 316L and we plan to production weld with 304.
Anyone with comments?
Regards,
Vonash
Parent - - By ajoy (**) Date 07-22-2004 10:47
If you change from 316L grade to 304 Grade of Stainless steel, you may change your filler wire / electrode from E 316L to E308/E308L type to match the parent metal chemical properties and reduce cost of filler wire. As far as ASME SEC-IX is concerned, neither the P no, F no. nor A no. is being changed and so requalification is not required.However AWS classification of the filler is a supplimentary essential variable ( when the material requires impact properties ) and when the filler is being used as a corrosion resistance alloy.
Parent - By jon20013 (*****) Date 07-22-2004 11:52
I agree.
