Up Topic Welding Industry / Technical Discussions / Quite Metal
- - By kam (**) Date 07-22-2004 13:33
Whats the scoop on this "quite metal" that Ford is using in there new trucks? Just curious. Chemistry, microstructure, basic mechanical properties. Would be interesting to have a look at it under a microscope.
Thanks
kam
Parent - By swnorris (****) Date 07-22-2004 17:24
Hi Kam,
It's actually called Quiet Steel and it is manufactured by Material Sciences Corporation Engineered Materials and Solutions Group. Lifted from a different website: Quiet Steel is a laminate of (1) a layer of steel (usually 0.5 to 1.5 mm) (2) a viscoelastic layer (about 0.001 “ of an engineered plastic which can be conductive for spot or stud welding) and (3) another layer of steel, same thickness as the first layer.
http://www.quietsteel.com/quietsteel.html
