I read in a book, that if done properly, a brazed joint could actually be stronger than the rest of the steel!!! I don't see how that is, but okay. Now, I need a very strong joint on a truck-frame, but I am forced to do this vertically. I already tryed MIG welding it, but I did so bad I had to cut the bracket off and start over. I was wondering if I could possibly braze it. Does brazing work okay when done vertically? Also, this would basically be a "T-joint". Can you get good strength when brazing a T-joint? Any information would be greatly appreciated!
