Up Topic Welding Industry / General Welding Discussion / BBQ Grill Plans
- - By C. Bates Date 08-02-2004 23:54
Hey guys... does anyone have any plans for BBQ Grills, Smokers or Pits?
Thanks in advance..
Parent - By swnorris (****) Date 08-03-2004 12:07
Hi C. Bates,
Check these out:
http://www.lincolnelectric.com/knowledge/articles/content/bbq.asp
http://www.thesmokering.com/pits/metalpit/bigbaby/default.jsp
Parent - By jwright650 (*****) Date 08-03-2004 12:51
Watch out if you plan to use an old 55 gal. drum, it may have had something in it that would have dangerous fumes cooking into your food. Just because it looks clean or has had a fire in it already doesn't mean it's fit to be used as a cooker.
Just thought I'd throw that out there as sometimes the obvious doesn't always ring a bell.
John Wright
Parent - By thirdeye (***) Date 08-03-2004 13:41
C. Bates,
Here is a link to the image gallery of the BBQ forum. There are currently 93 photographs of pits & smokers in various stages of construction. You might try searching their forum for plans or ideas. Just like the people on this forum, the BBQ folks are very helpful.
http://www.thebbqforum.com/gallery/categories.php?cat_id=8&sessionid=0f105925355338337c9e70f358146d17
Parent - By jwright650 (*****) Date 08-04-2004 11:07
If I remember correctly, some of those blacksmithing web sites have lots of cooker ideas from small one's to some that you pull behind your pickup(propane, wood or charcoal).
just a thought,
John Wright
Parent - By thirdeye (***) Date 09-06-2004 02:33
I knew I had this link...just couldn't locate it. Better late than never.
It has a few good tips.
http://www.exit201.com/cyclops/cyclops.html
Parent - - By matt sr Date 09-07-2004 20:07
Been building smokers and bbqs for 5 years, any questions please email me and i will send you plans and designs of which we build here.
Parent - By tompit9 (***) Date 02-26-2010 01:23
I'm about to cut up a propane tank (1st one). I have it filled w/water but the tank has been opened for 3 years or so, just a 3" hole. any info would be great. Thnx
Parent - - By OSUtigger (**) Date 09-07-2004 20:23
Hey,
Just thought I would throw this one in-one me and a bunch of buddy's are really proud of, 7000 lbs worth of steel and unimaginable man hours dedicated to a single purpose- cooking. Go here and scroll down to the "candids", the first five pictures are of this monstrosity at work.
http://biosystems.okstate.edu/cowboymotorsports/Pages/ArtifactsPhotos_files/frame.htm
For reference, I fit fairly comfortably IN the firebox for the smoker, and the party deck is around 10 ft. high.
I believe I can say we went way beyond tailgating on this one...
G. L.
Parent - - By - Date 09-09-2004 21:47
Tigger,
great link to the tractor project. Can you share more details of the tractor, eg. drive system, gearing, etc.
thanks,
Andrew
Parent - - By OSUtigger (**) Date 09-10-2004 03:18
Andrew,
You may have just opened a pandora's box, mano, but here goes.... The tractor is a 1/4 scale about 8ft long by 5 ft wide according to regulations. We are given a 16 hp Briggs and Stratton motor, which cannot have any more modifications than exhaust and oil changes, and tires, which we must use, but can cut to a tread pattern of our desire. Drive system is where it gets complicated. The orange tractor you saw on the site utilized a hydro-mechanical, stepless transmission. Basically it behaves like an automatic transmission that does not have shift points because there is only one gear, but the gear ratio can change, if that makes any sense at all. What this does is allow us to "shift" from high gear (about .80:1, or a common overdrive) to low gear (technically, it shouldn't go below 3:1 under without breaking the planetary gear or drive shafts, but we once had it below 100:1, yes below 100:1 without snapping anything when we weighed 3000lbs, and down to infinite:1 without load) without the engine ever leaving 3100 rpm, or peak horsepower, and pull about 80% efficiency. We attempted to patent this transmission, however intellectual properties here on campus significantly reduced their services and funding ran short, so we did not, even though we did basically have the go ahead. Beyond the transmission, its stepped about another 50:1 before heading to the tires, where top speed is about 10mph, and basically no lowest speed. It is four wheel drive, and the tractor, without driver but with fluids and all components, cannot weigh over 850lbs and is pulled in 1000, 1250, 1500, and 1750 lb classes. The sled we pull weighs about 6000lbs. It has some extreme bells and whistles and in the end the finished product cost about $10000 to $15000 for parts, and about 1800 man hours worth of labor, a great portion of which is welding and is ALL mine. This, of course, translated into a production model, would be around $3500 worth of parts and labor total, showing just how handmade this thing is.
The competition is inter-collegiate(28 total this last year) and international, including several Canadian colleges, in the past has involved a Malaysian college, and we have heard rumors of an Ireland college having interest. All that said, we brought home the championship with the orange one you saw.
I could go on, but a lot of info can be found on
www.ASAE.org
if you are more interested in rules and stuff. If you want to know more, just ask, I've been involved in it the last 4 yrs.
G. L.
Parent - By jwright650 (*****) Date 09-10-2004 11:20
G.L.
I enjoyed the trip around your site looking at all the tractors you all have built over the past years. Very interesting indeed, I love that kind of stuff anyway. Thanks for sharing.
John Wright
Parent - - By dfdever Date 03-10-2005 04:27
www.compuvices.com/smokers.html
This is the one I'm building, but downsizing a little.
Plans are for a 500 gallon propane tank!!
dfdever
Parent - By jwright650 (*****) Date 03-10-2005 13:52
http://www.compuserve.com/smokers.html
Note: adding the http:// makes it a clickable link ;)
EDIT: but something might be spelled wrong in this case?
John Wright
Parent - - By ctacker (****) Date 08-21-2008 04:39
check these out too!
Attachment: bbq11.bmp (368k)
Attachment: bbq22.bmp (949k)
Parent - By jrw159 (*****) Date 08-21-2008 13:30
Those are two of the coolest BBQ set-ups I think I have ever seen. :-)
jrw159
Parent - - By jwright650 (*****) Date 08-21-2008 13:37
That 2nd picture sorta reminds me of this grill......
http://www.megabbq.com/?p=49
Parent - By jrw159 (*****) Date 08-21-2008 13:56
SWEET!!
Parent - - By thirdeye (***) Date 08-23-2008 14:09
Here is another cool pit
Parent - By jrw159 (*****) Date 08-23-2008 14:10
YES!!!!
That is awsome!!
jrw159
