Hello everyone,
I am a homebrewer who is very interested in welding and needs to fix a kettle for brewing. The riveted handles on the brewing kettle (stainless steel pot) that I own leak. I am trying to figure out how to fix the problem. I have a heat gun that goes up to 1050 degrees F. I have looked somewhat into silver solder but do not know much about it, and if I would be able to fix the leak using it. Would I be able to perform this with a heat gun? If so what percentage silver should I look for in the silver solder I purchase. Please keep in mind that it must be food grade and be able to withstand at least 220 degrees F (which I'm sure will not be a problem).
I have also spent some time looking into the Bernzomatic setups. Would any of these work, and would they work better than the heat gun? If so which ones, propane, mapp, or a mixture with oxygen? Also any tips on what types of fluxes I should use (if any) for my project?
As I stated before I am very interested in learning how to weld, but I need to have this fixed soon so that I can resume brewing. Would I be better off to have the leaking handles welded at some sort of weld shop and how much would this run me? There are 4 rivets per handle, and two handles on the kettle. I truely appreciate anyone's suggestions, tips, advice, and their time.
Thanks
- Mike
