I had some old info on HY-80 welding to MIL-STD-1688 and MIL-STD-248 that had a 55,000 joules/inch maximum heat input. The heat input was controlled by limiting bead length for a 12 inch long SMAW electrode. The ranges were:
Diameter Bead Length per 12" Electrode Burn Off
3/32" 1-5/8" to 4-1/8"
1/8" 3-3/8" to 5-3/16"
5/32" 4-3/8" to 6-3/4"
3/16" 6-1/4" to 10"
7/32" 11-3/8" to 16-1/4" (14" burnoff)
The last two sizes are definitely not for the weak of heart!
The above would not be very practical if you wanted to use GTAW or FCAW. You could use the heat input formula to determine the minimum travel speed for each electrode size on your welding procedure. The formula is:
Heat Input (joules/inch) = (volts x amps x 60)/travel speed in inches/minute
Determine a reasonable maximum amperage and voltage for each electrode size and use 55,000 J/inch in the above formula to find the minimum travel speed for the welding procedure.
Example:
Rearranging the formula to find minimum travel speed,
Min. Travel Speed (inches/min) = (volts x amps x 60)/55,000
For a 3/32" electrode with a limit of 21 volts and 100 amps, the min. travel speed to keep heat input below 55,000 J/inch would be:
Min Travel Speed = (21 V x 100 A x 60)/55,000 = 2.3 inches/minute minimum
Just be careful that the minimum travel speeds you calculate are practical for the welder. You don't want to push the travel speed so high that you have narrow, ropey beads with poor fusion. Keep the current and voltage ranges practical too. Voltage is controlled manually by the welder's arc length and they will not want it to be so low that it is hard to see the puddle and the puddle does not flow well. Talk to the welders and find a happy medium.
Hope this helps.
Marty Sims
