Up Topic Welding Industry / General Welding Discussion / D1.1 QUESTION
- - By emljr (*) Date 08-19-2004 13:59
SPECIFICS:
1/8" E7018
3G UPWARD PROGRESSION
BUTT JOINT (B-U2a)
BACKGROUND;
SPLICING LOAD CARRYING W-SHAPES ( W-24 AND BETTER)
QUESTION:
WHAT IS THE MAXIMUN WEAVE WIDTH FOR THIS SIZE ROD IN THIS POSITION?
IS THERE A D1.1 REFERENCE TO SAY AS MUCH?
DID I GIVE ENOUGH INFORMATION?
THANK YOU.
Parent - By swnorris (****) Date 08-19-2004 14:17
Hi emljr,
In D1.1 2004, under General WPS Requirements, look at 3.7.2, Width/Depth Pass Limitation, and Figure 3.1. These work in conjunction with Table 3.7 as they apply. Also, the commentary at C3.7.2 may be helpful.
Parent - - By emljr (*) Date 08-19-2004 17:50
I KEEP HEARING THAT 4 TIMES THE DIAMETER OF THE ROD BEING USED IS MAX WIDTH FOR A WAEVE BEAD.
SO A 1/8" ROD WOULD ONLY BE ABLE TO PUT DOWN A 1/2" WIDE WEAVE.
IS THERE HEARSAY OR CODE?
Parent - By CHGuilford (****) Date 08-19-2004 22:43
AWS D1.1 does not specifically address the max width of a weave. As SWNorris mentioned, there are limitations on the width and depth of an individual bead. Also there could be heat input limitations that have the same end result.
Maximum weave sizes are more often leftover notions from the past practices of old codes. A lot of people remember having to limit the weave but don't know where it came from. There may be some codes the do have the limitations but D1.1 isn't one of them.
Hope that helps,
Chet Guilford
