Cronatron 211 is the electrode for the job.
“THE CAST IRON PROBLEM SOLVER”
Unquestionably the final answer to the most difficult cast iron repair welding. This highly sophisticated
alloy allows repairs that were previously impossible.
IDENTIFICATION: Printed Electrode, TIG Flagged One End
APPLICATION: AC or DC Reverse Polarity
CRONACAST 211 SUPERIOR ADVANTAGES:
• HIGH TENSILE WELDS IN EVERY TYPE OF CAST IRON, INCLUDING GREY AND
MEEHANITE; ALSO PRODUCES EXCELLENT STEEL TO CAST IRON WELDS
• CRONAMIG 211 IS FULLY MACHINABLE AND HAS A HIGH ELONGATION
FACTOR WHICH POSITIVELY PREVENTS CRACKING
• PASS OVER PASS WELDING WITHOUT SLAG REMOVAL BETWEEN PASSES
• ALL POSITION WELDING CAN BE DONE WITH CRONAMIG 211 WITH NO
DISMANTLING OF EQUIPMENT PARTS
TECHNICAL INFORMATION:
TENSILE STRENGTH: 70,000 PSI (483 MPa)
BRINELL HARDNESS: 185-240
OPERATING PROCEDURES:
Use AC or DC reverse polarity. Generally, where a narrow, thin
bead is desired a straight polarity application is suggested.
APPLICATIONS:
• GEAR TEETH • PUMP IMPELLERS
• SPROCKETS • CAST IRON TO STEEL
• PUMP HOUSINGS • CYLINDER BLOCKS AND HEADS
• BEARING HOUSINGS • TRANSMISSION CASES
• TURBINES • HYDRAULIC PRESS RAMS
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 02)
PART
NO.
CW1035
CW1034
CW1033
CW1032
ELECTRODE
SIZE
3/32
1/8
5/32
3/16
AMPERAGE
55-95
75-110
120-150
140-175
COMBO PAC . . . . . . . . CW1725
PART NO.
CW1901
CW1902
CW1903
SIZES
CRONATIG™ 211T
1/16 x 36
3/32 x 36
1/8 x 36
CRONATRON WELDING SYSTEMS, INC.
CRONACAST ™ 211
CRONAMIG 211M-FC CRONATIG ™ 211T
PART NO.
CW2065
CW2066
CW2057
CW2058
CW2059
SIZES
CRONAMIG™ 211M-FC
.035 x 10 lbs.
.035 x 33 lbs.
.045 x 10 lbs.
.045 x 33 lbs.
.062 x 33 lbs.
WE 14 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com
Return to Index
