The big thing about this particular weld is that the chemistry of any stainless (300 series)
must be kept above the magical 18/8 chrome/nickel ratio for good mechanicals and max corrosion resistance.
If we weld with a lower grade filler, say, 308-the dilution (ratio of filler metal and base material) may be very well lower in chemistry than this 18/8 requirement.
ER309, with it's elevated chrome and nickel content can produce a weld chemistry above the magical 18/8, even with normal dilution.
Hope this helps
Good Luck
brande
