Up Topic American Welding Society Services / Certifications / Prequalified D1.1 tube steel splice ??
- - By ckjoin Date 08-30-2004 18:18
[deleted]
Parent - By jwright650 (*****) Date 08-31-2004 14:26
AWS D1.1 :2004 Table 3.1 and Annex M list the prequalified base materials. Table 3.7 list the prequalified WPS requirements. Figure 3.3 list all of the prequalified joint configurations. Keep in mind you will need to use a backing ring to maintain a prequalified status, due to the lack of access to backgouge the second side(see paragraph 3.13.3[1][2]).
HTH,
John Wright
Parent - - By thcqci (***) Date 08-31-2004 17:24
Posted a reply yesterday but don't know where it went.
I simply said that in my opinion, "prequalified" addresses the joint itself. It addresses the geometry, process and materials used to fill the joint. It does not address whether you are joining plate, shapes, pipe, square or rectangular tubing. I do not have a separate pWPS for tubing, plate, shape, etc.
Parent - By ckjoin Date 08-31-2004 17:45
THANKS FOR THE INFO IT REALLY HELPED!
