Because the local dihedral angle is < 30 degrees on the K- connection, I need to qualify a new WPS for the K- connection. This will be my first.
After reviewing D1.1:2004 Section 4, Part B, 4.13 and referring to Table 4.3 I have a question.
I am assuming that because the local dihedral angle is < 30 degrees my test coupon will be the actual K- connection (one side only) rather than a typical pipe test coupon. Am I correct in this?
If so, my next question is the location of the test specimens. According to Table 4.3 the WPS qualification will require macroetch, reduced section as well as bends.
If you have some insight it would be greatly appreciated.
Thank you.
ziggy
