I am having difficulty with the consistancy of weld strength while welding a 8MM nut onto 2mm thick galvanized steel. Any suggestions for typical setup or general practice for welding this material? I can get a good weld but with alot of flash which is damaging the threads on the nut. I am getting contradicting statements from different people on how i should set this up. Any ideas?
