Up Topic Welding Industry / Technical Discussions / Gas usage
- - By Josh Clare (*) Date 10-02-2000 14:39
Does anyone know how to calclulate the amount of gas volume used from a torch. I have an automated system that uses four 1/4" gas lines to feed two seperate torches. The pressures are set at 15 psi for the oxygen and 4.5 psi for the natural gas. I need to know the amount of gas used at these pressures for a given amount of time that they are on. If anyone could help I'd appreciate it.
Thanks,
Parent - By G.S.Crisi (****) Date 10-02-2000 18:36
Dear Josh,
Yes, it's possible. However, a lot of calculations must be done. The calculations will be based on assumptions which may or may not be true. So, the easiest way to figure out the gas consumption is to get in contact with a torch manufaturer and ask him which are the average consumptions.
Take into account that:
a) torch sizes (at least in Brazil) are identyfied by a number, regardless of who's the manufacturer. So, any manufacturer will be able to answer that question.
b) the consumptios he'll inform you are AVERAGE ones. Anyway, they'll be more reliable than the ones you may calculate.
