Up Topic Welding Industry / Technical Discussions / pressure welding
- - By okanagan Date 09-28-2004 15:28
Is there a specification, controlled process, or company who can do Pressure Welding?
We have a drawing which joins 4130 tubing to a 4130 forging, which calls for either flash weld or pressure weld. I understand this is a form of upset welding. Problem is, the drawing is fairly old and we don't know which process was actually used or how it was originally done. We have been advised that flash welding is impractical because there isn't enough room for the collar to fit on the forging side.
Any information would be appreciated.
Thanks
Parent - - By scmait (*) Date 09-28-2004 19:24
We do both. I am a Welding Engineer that takes care of both processes. Problem is for me to help I would need to see a sketch of or the actual drawings. If you would like post the dimensions that need to be welded or email me.
SCMait
Parent - - By okanagan Date 10-12-2004 15:40
SCMait- we sent some details via email. Did you receive them?
thanks
Parent - By scmait (*) Date 10-14-2004 00:24
No I have not recieved your email. Could you try again?
SCMait
