Have utilized both ER120 & ER140 on several "projects" and material weld applications over the years. When you move into that material strength range as one other respondant noted use the best filler material available or it will come back to haunt you. What you really need is the old L-TEC ER130 but it no longer made. The ER120 without specific chemistry controls & specific modifications from the AWS spec, will not consistantly meet 120ksi YS simply because of variations in the wire heat to heat chemistry allowed by AWS and the ER140 is a bit of an overmatch, so you will have to weigh your end service requirements against the wire deposit properties. ER 120 & ER140 is difficult to find right now because of steel prices. The best material available cleanliness and chemistry wise is US Welding, Sandvik makes the ER120 & ER140 and in my opinion is the best commercial wire available. Best of luck.
