In section 7.1 note(1) of D1.1:2000 the codes says "specific requirments: (1) ... testing when required, ..."
Does this indicate that the customer/contractor will indicate, in a project including stud welding being done to D1.1, whether stud welds will be tested to section 7 or to use the manufactors setting reccomendations along with VT to verify quality.
Thanks,
James
