Using .035 solid wire, 95% argon 5% oxygen, 50 cfh, about 28.5 Volts, and about 700 to 800 ipm. You get a good spray at around 600 ipm. What do you call the process if you run the wire speed up past the spray arc and you get a frying sound and spatter?
