You did not specify an electrode size.
Rule of Thumb (starting point) 1 amp for every .001" of filler OD. AC/DC. I suppose 39 Amps /MM.
Example: For 1/8" rod you would start around 100 ~125 amps, 3/32" rod / 90 ~100 amps and adjust accordingly to you conditions.
14 gauge is a little lite for 1/8" electrode so you would not want to use that much amperage. 1/16" (60 amps), 5/64" (80 amps) or 3/32" would be more suitable.
While 6013 is suitable for AC I feel DC will run smoother.
