May I get an answer for the following situation.
A WPS was qualified as per AWS D1.1 for TKY joints. Qualification was done using standard pipe 8" Sch.80, 12.7mm thk minimum(fig.4.27) .This was impact tested at -20 degree celcius.
a. Can this wps be used for production TKY jts with thickness less than 12.7mm, with impact at -20 degree?
b. Can this wps be applied for a production TKY jonts with diameter less than 4" ?
Note :AS per fig 4.27 the minimum diameter and thickness of the test coupon are specifed ( ie., 6" min , 12 mm thk minimum , and 5 mm offset min) and supplimentary essential variabl list for CVN impact requirement limits the thickness qualified to 16 mm or the minimum thickness welded. Also as per table 4.2 min. dia. qualified shall be 4" if test has been made on standard size pipe 6" sch 120 or 8" sch 80
