Excellent Advice G!!!
Welcome nspc6f to the forum!
Like Gerald, I've worked on both sides of the "fence" so to speak and. I have to agree with his opinion wholeheartedly!!!
There are always some "bad apples" in both union and non-union trades.
The ones that stay on the jobs longest always get the bad rep because, of the few that are eventually no longer on the job...
Sure, it may take a little longer to get rid of "dead weight" if they have some seniority (in the union) but, they either shape up or ship out!
The ones that are constantly busy are usually among the best and most reliable and, that's why there always in demand, get assigned to the next job first...
Different jobs require different amounts of manpower so eventually, a local will run out of enough "A" list and "B' list members... This requires them to request help in the case of the Boilermakers, from the NTL (National Transient Local) which was designed to help fill manpower requirements for the different locals located across the country and sometimes in Canada or visa versa... What I'm getting at is this; sometimes contractors will get manpower from different regions that may not be used to the work ethic that may or may not be present in a certain region or local and, this may or may not result in management developing unfavorable opinions concerning some of these individuals and visa versa but, it's not always the case because, I know quite a few excellent NTL journeymen that eventually find a local that they develop a mutual respect for each other and, that person ends up on there "A" list or at least their "B" list... Heck, I was on both lists at quite a few locals in my career as a Boilermaker and, had both pleasant & difficult experiences when I was with the NTL...
BTW, which location were you at when you were at Tulsa Welding School? Good school but, not the end of your training -only the beginning!!!
Gerald, I dobt it very much that all of these so called "Master Welder" types could perform some of the welding we had to do when we worked on our favorite "pressure vessels" if you get my meaning!!! At least I have'nt ran into one that would accept some of the more challenging jobs we were qualified to perform - "mirror, mirror on the wall or should I say walls" because I know that I sometimes had to use more than one and,I know you did too pal!!! nspc6f, you may want to ask these master welders that you know if they've done any mirror welding before and, I do'nt just mean with SMAW!!! Alot of GTAW pipe welding that me and Gerald did, required some of the joints to be either partially or fully mirror welded and it was a rarity when we encountered a fully accessable pipe joint that did'nt require the use of a mirror or two or even three in some locations where in some instances, pipe hangers or other weldments that because of poor planning, conflicting schedules, the lack of modular construction or shoddy workmanship required repairs after everything else including the "kitchen sink" was installed - making it unjustifiable to rip out whatever was obstructing our veiw in order to repair or add on a run or another hanger, structural component, machined surface from a revision in the design for whatever reason or because a component was completely overlooked if you catch my drift... Even arc strikes had to be repaired and they were usually noticed after everything else was installed so, if you want to know who were or are in my opinion Master welders? The men and women that did and still can perform this type of work including the ones that do this type of work today because, not only can they perform the work to a consistent level of quality that would be the envy of many experienced welders without this exposure... They also can without hesitation, explain all of the technical aspects occurring before, during and after the welding is performed and justify why this type of welding is necessary or not.
The AWS has entry, advanced and master or is it expert level welder designations at least from what I can recall (please correct me if I'm incorrect) and I'm not knocking their requirements but, I'd like to see if the master level designations could handle some of the work that I know Gerald and a few other gentlemen including myself (well I'm not always a gentle person but that's another story) have experience with, in a "baptism by fire" situation where they were only shown and allowed to practice with a mirror or two or three (if they could handle that many) for a week, then find out if there level of quality passes muster, meaning MT, PT, RT & UT on a mock up!!!
Throw them inside a United States Navy Warship - preferrably a nuclear powered submarine that's already packed to the "gills" and perform this type of work and, achieve the same consistent level of quality workmanship that is required in order to be qualified to perform this to say the least, type of welding in such challenging working environment...
Now do'nt get me wrong, there are some gentlemen that can perform this level of expertise without ever having Gerald's or my experience but, not many of them exist... I do recall a recent article in the welding journal showcasing repair welding of certain components that are found in our nation's NASA Space Shuttle fleet and I must say that I was impressed with the challenges that were overcome in order to successfully complete the work and. the conditions in order to do so...
Nonetheless, some of the conditions we encountered rose to that same level!
Anywho, If I were in your shoes, I'd take full advantage of the Pipefitters or Ironworkers union offers because, they offer training that will definitely help in your career advancement and, they'll even help you out in paying for your welding engineering degree if you can handle everything else, especially the mathematical proficiency, physics, metallurgy, proficiency in inspection methodologies, best practices, etc., that is required of you just to continue towards your goal of becoming a decent one. All of the welding experience that you'll gain in a variety of processes and conditions will also give you a unique perspective that other students in your class might not have...
Therefore, giving you an advantage that others may not be able to handle. In other words, you will be able to graduate and hit the ground running as opposed to learning how to walk first!
All of your goals can be achieved and on top of that, while you're reaching for your goals, your getting paid a decent wage and you do'nt have to pay for any of the training!!! Who could ask for anything better than that??? Unless you do'nt mind spending alot of money on your own!
My advice to you, from somone that was offered a teaching position at Tulsa Welding School when they opened their facility in Jacksonville, Florida, which I turned down because, I recieved a more convenient offer locally in Pittsburgh, PA, is to reconsider the Pipefitter's local offer because, the local Steamfitters as they're called here in Pittsburgh, have training facilities in all regions of the US that meet and surpass any of the schools that you have to pay for period!!!
Now do'nt expect Journeymans status immediately unless you have enough documented experience in man hours in order for them to justify granting you that status. Besides, like anything else, they'll find something that is a requirement to achieve (yes, you have to work for it) Journeymans status that you may need training in to meet their standards...
If I were you I'd take another look! Buono Fortuno!
SSBN727 Run Silent... Run Deep!!!
