domestic:
There are several items to be considered:
1.) Is this an in-process correction, repair or rework?
(These typically determine the course of corrective action.)
2.) Does the GE spec. reference D17.1 specifically?
(Do not consider other AWS, AMS, MIL-STD's, etc. if not part of the GE criteria.)
3.) If D17.1 is referenced, has the criteria modified?
(Raytheon, Boeing, etc. all reference D17.1, but the criteria is often modified and tailored to their specific requirements.)
If your not sure, I would inquire to the Engineeing Authority or its designee. If additional info is posted, you may get the help you need from the forum.
DGXL :
This is the rework and should be reference D17.1 specifically but I not sure for criteria modifile of D17.1 ,Cos I'm quality inspector for all assembly component parts such as bracket, tube manifold,link is not directly for welding inspector,My location in thailand,I would be learn more with you,Can you help me please ?
While D17.1 is an Aerospace welding specification and has a "small" section covering repair. It would not in your wildest dreams approach the comprehensiveness that General Electric provides in it's own specifications.
The big question here is; Why haven't you aquired the GE doccuments that will answer all your questions?
D17.1 cannot and will not be able to give you specific criteria conserning air flow or faying surfaces, nor will it determine stress relief requirements in inconel tubes. D17 delineates 3 visual inspection catagories for titanium weldments, has GE accepted this in your particular situation? Only GE can tell you these things.
Here in the states we work under the authority of the Federal Aviaition Administration (FAA), and *cannot* undertake repair of flight hardware without proper authorizing doccumentation. This doccumentation is provided or approved by the aircraft/engine manufacture and has all the control details necessary (most of the time). Being in Thailand you may not be bound by that mandate but I urge you to try to see the wisdom behind it.
Edit: This is one of the *two* paragraphs D17 devotes to repair.
AWS D17.1 2001
5.20.1 Repair Instructions.
The Engineering Authority or it's designee shall provide detailed instructions for the repair that include but are not limited to:
(1) allowed number of weld corrections during the repair
(2) required doccumentation
(3) Details for each operation (including acceptance inspection) involved in the repair.
