Up Topic Welding Industry / Technical Discussions / Heating and cooling rate for PWHT
- - By peterbil (*) Date 11-12-2004 00:15
I'm trying to determine the heating and cooling rate for PWHT of base metal 1 inch thick SA-216 overlayed with ER316L and 1 inch thick 4130 overlayed with ER316L is there any formula or references I could look into, I'm preparing a WPS and I don't want to guess here I believe this is the right place to ask, can you help me? I will appreciate your reply
Roger
Parent - - By RonG (****) Date 11-12-2004 12:51
A standard up & down ramp is 200'F(93C) per hour beginning & ending at 600'F(315C).
Most usually it is OK to unwrap or take it out of the oven anytime below 600' in to still air. If you are working out side, consider weather conditions concerning that last item.
Parent - By peterbil (*) Date 11-13-2004 02:05
Hi Ron,
Thanks for your reply I can decide now what to put in my WPS.
Cheers
