i am making a steel tubing frame using 1 x 1 x 0.062 material. No fancy 45 deg. corners, just square ends. What is a good electrode size and amperage to get a good weld? In the past I have had trouble with this thin tubing.
Also, what temperature should I dry my electrodes to? the ones I have are probably quite wet.
thanks,
