The only difference in the AWS specification is that E7018-1 is impact tested at a lower temperature. (-50F vs -20F). Manufacturers may tend to use higher manganese in order to accomplish this, but it is not required, and the chemistry ranges for them are identical. (1.6 Mn max)
