weber:
The comments by thirdeye apply and are still applicable to the 2001 revision of the "Recommended Practice".
Not sure why an argument would be in order. Myself, I would strive to retest and concentrate on passing it the next time around. TWI is a well respected entity in the welding industry and I don't think they are out to dupe anyone.
I recommend further practice and study the required 30 days (8.9), then retest. I don't think you will meet anyone in this forum who has not failed a test of any type in their careers. Save yourself the frustration of a confrontation and focus your energy on passing the next time around.
Good luck on your next test. Post a reply in 30 days and let the forum know how you did.
weber,
I posted the excerpts above, to make the following points:
1. TWI acknowledges that employer specific certification requirements are to be specified by the employer.
2. The SNT-TC-1A document contains recommendations only, it is not a specification. It is not mandatory for an employers written practice to follow all of the recommendations in the SNT-TC-1A. (It should be noted that upon outside review of a written practice, areas that do not meet the recommendations of the document are usually not acceptable under most circumstances).
3. The SNT-TC-1A document recommends that a passing grade on individual examinations be not less than 70% with the composite grade being at least 80%.
DGXL points out that many written practices, including his, are stricter that the recommendations in the SNT-TC-1A document with respect to passing grades on examinations. Mine is as well. In addition my practical and specific examinations have been modified to focus more on the applications in my area(s) of NDT. If, for example, both DGXL and myself hired TWI to conduct NDT examinations on some prospective employees, both of our companies would submit copies of our written practice and examinations to TWI. TWI would review each written practice and would then certify each individual in accordance with the respective written practice.
It sounds like you are self employed, took some training from TWI and then followed with an examination. You are using them as your outside agency. Did they have a “model” written practice or do you have your own? Did they explain the examination criteria to you prior to taking the examinations?
