Up Topic Welding Industry / Technical Discussions / HF TIG PROBLEM
- - By bullvine1 Date 12-11-2004 23:40
HI GUYS I'M NEW TO THIS FORUM SO IF YOU CAN HELP ME ALONG IT WILL BE MUCH APPRECIATED.I HAVE A 160 AMP HF TIG SET,I'VE WELDED SS PLUS CARBON STEELS AND ALSO CASTS.THE PROBLEM THAT I HAVE IS ARC WANDER,NO MATTER HOW I ADJUST THE SET IT WONT GO AWAY SOME TIMES IT WILL WORK FINE AND OTHER TIMES IT WONT.IF THERE IS A COMMON FAULT AT HAND CAN YOU POINT ME IN THE RIGHT DIRECTION.
CHEERS
Parent - By Mike W (**) Date 12-14-2004 04:21
Perhaps this may help you: http://www.diamondground.com/gb3.html
Parent - By brande (***) Date 12-18-2004 06:13
Arc wandering is typically caused by using too large a tungsten diameter for the amperages anticipated.
If wandering is a problem, go to the next smaller tungsten.
As an aside-when starting to weld-nail the foot pedal. You can always reduce amps.
Amerage range charts are available from:
Millerwelds.com
Lincolnelectric.com
Diamondgroundproducts.com
The Tig Guy
and many other resources.
Additionally, if you let me know what you are welding, I can probably give you tips and a procedure for your weldments.
Good Luck
brande
Parent - By jwm80 Date 01-29-2005 22:17
First of all, if you cannot maintain a nice point on the tip of the tungsten then you obviously need to try 3/32 size. If your tungsten is to far from your base metal at ignition then you will hear a HF buzzing noise out of your machine and its important always use a SHARP tungsten. I can't stress that enough!
