Hi Doug,
FEMA 353, Recommended Specifications and Quality Assurance Guidelines for Steel Moment-Frame Construction for Seismic Applications, provides supplemental design and fabrication recommendations and supplemental quality control and quality assurance recommendations for the construction of steel moment frame structures designed for seismic applications. FEMA 353 is designed to supplement other welding codes, such as AWS D1.1, and The AISC Manual of Steel Construction LRFD. FEMA 353 contains provisions that affect welder qualification, filler metals that can be used, welding procedure specifications, inspection practices, and other issues. FEMA 353 has numerous recommendations beyond the "normal" parameters of D1.1. Lincoln Electric has an easy to read brochure, FEMA 353 Welding Manual (C1.60), that summarizes many of the main welding recommendations in FEMA 353. Here's a link to the 36 page manual on the Lincoln site that may be helpful:
http://content.lincolnelectric.com/pdfs/products/literature/c160.pdf
Thanks. Got that and a couple of other articles that have been published the last couple of years (http://www.aws.org/wj/mar02/feature2.html, http://www2.thefabricator.com/Articles/Welding_Article.cfm?ID=69) and sent them to upper management so they could get a feel for the tiger they are trying to catch by the tail. As a design-build fabricator for our corporate "monster", we make our mark by turning steel around quickly, keeping the main office happy. The longer the job is strung out, the poorer we seem to perform. We thrive on quick turnaround projects. This definitely does not seem like the kind of project we do well. Has the shop scared as to what we will be asked to fabricate, whether we think it is our best interest (ie; bottom line - still have to feed the monster downtown) or not. Don't get me wrong, I want to be able to fabricate this sort of project. It would be very benificial for our personnel to experience a project like this. But to jump into a project of this magnitude without taking an intermediate step is scary. Espescially when I have had trouble getting everyone on board and organized to submit to an AISC audit!
By albcwi
Date 12-23-2004 22:54
Just wanted to pass on some info that we learned about in our first job under FEMA 353 guidelines. This was our first job under these guidelines and it ate us up. We were not prepared for the requirements and I received this info as the job hit the shop. You really want to look at the estimating end for time to produce the project. It took us approximately twice as long to produce than original estimates due to the requirements. The AISC has incorporated the reccomendations from FEMA in the 2002 Seismic Provision document. They also provide an online seminar at their website. Just be careful about time estimates for fabrication. Hope this provides a little insight to your concerns.
