Hello everyone, I have a 1995 Pontiac Grand Prix GTP that has 5 spoke aluminum rims, every other day I have to add air to the drivers front. I had a shop check it for a leak and turns out the inside lip of the rim has a crack. Can I have the shop remove the tire from the rim, I'll weld it and machine it off and have the tire replaced without any trouble? Are rims heat treated? I am assuming the rim is cast, just curious if anybody else has done this before with success.
Thanks
Christopher Martin
