Up Topic Welding Industry / General Welding Discussion / removing the oil
- - By rm Date 12-25-2004 00:09
what is the best way to take the oil off of new steel ?thanks for any help
Parent - By BIG E (*) Date 12-26-2004 04:40
persure wash it off. or I have heard guys take there oxy acetyene and burn it off?
Parent - - By bmaas1 (***) Date 12-27-2004 18:15
What type of steel?
Sheet, structural, etc.
Brian
Parent - - By rm Date 12-28-2004 04:51
mild steel square tubing.
Parent - By billvanderhoof (****) Date 12-28-2004 05:37
A rag and mineral spirits is probably good enough for a start. If you are using tig you may need to do more. Since said rag is quite flammable you will want to protect it from welding sparks either by wiping everything first, and then removing all flammables before starting to weld, or by keeping the rag in a fireproof container such as a paint can with a lid while welding.
If this is a large operation disposal of used rags and solvent may have environmental implications.
Bill
