Up Topic Welders and Inspectors / Welding Equipment Classifieds / Water Plasma Welding Tools
- - By juatorsal Date 12-26-2004 12:14
I heard it is now possible to weld and cut without using plasma hole/shielding gases, just water to generate micro-plasma, cooling and protecting the welding pool for less than 2000 €. Did any of you heard the same ?. Any manofacturer ?. Thanks many.
Parent - - By lisasekiko (*) Date 12-28-2004 12:19
Yes,i'm also hearing about water plasma cutter before.
Parent - - By juatorsal Date 12-30-2004 07:58
Yes but, where and what did you heard ?
Parent - By lisasekiko (*) Date 01-05-2005 05:09
I have asked a engineer they are told me can take the air plasma cutter modify to water plasma.
msn:lisasekiko@hotmail.com
