Up Topic Welding Industry / Technical Discussions / STAINLESS STUD TO CARBON STEEL
- - By - Date 10-14-2000 14:48
CAN I WELD A STAINLESS STUD TO A-36 WITH A 70 SERIES WIRE?
Parent - By R. Johnson (**) Date 10-16-2000 15:56
Your ferrite number for the fillet weld will probably not be high enough and you will probably encounter cracking. This is why most applications of stainless steel to carbon steel use a E309 filler metal.
Parent - By Jorge Giraldo (**) Date 01-02-2001 20:04
There are so many different kinds of stainless steel (austenitic, ferritic, martensitic, duplex, etc) that is not possible to give an answer to your question. You should be more especific because the weldability depends of all the materials involves in the welding.
Jorge Giraldo
MedellĂ­n, Colombia
