If you are an AWS Member, have you looked at the Brazing Q & A Column that generally appears every other month in your Welding Journal??
If you are not a member it is time you become an AWS member so you will receive the Welding Journal and can read the Brazing Q & A Columns.
Each Brazing Q & A is the solution of a shop floor brazing problem from a company doing brazing. It also discusses many other brazing variables which could appear at another time. Eleven years of the previously monthly Brazing Q & A Columns starting in 1989 have been incorporated in a book titled BRAZING FOOTPRINTS. The book is available from Global Engineering Documents (800-854-7179), ASM and Wall Colmonoy Corp.
Give yourself a New Years Present, Happy New Year --- Bob Peaslee
