Good Morning, To do aluminum you will require an ac/dc machine. Probably the least expensive unit would be the Miller Econotig for about 500 or outfitted with accessories for about 850. You can get the Lincoln Square wave 175 with accessories for about 1175. Either is available here as well as all larger machines. Thanks, Larry
