Up Topic Welding Industry / General Welding Discussion / How to stop warping
- - By andyz Date 01-06-2005 11:57
I'm new to this site and somewhat of a novice welder. More of a hobbyist. Anyways when I am fabricating something out of angle iron or channel and I weld a piece perpindicular to another piece I get the base piece warping due to the heat on one side. How can I eliminate this? Or at least miminize it.
Parent - - By pipewelder_1999 (****) Date 01-06-2005 13:26
1) Tack it off well
2) Preset the piece where it will warp into place.
3) If the joint is long, backstep the welds.
Or any combination of the above.
Have a good day
Gerald Austin
Parent - - By andyz Date 01-07-2005 00:49
What is "backstepping"?
Parent - By pipewelder_1999 (****) Date 01-07-2005 02:14
Here is a brief example of the backstepping sequence. http://www.weldinginspectionsvcs.com/misc/backstepsequence.htm
Hope This Helps
Gerald Austin
Parent - By Dave (**) Date 01-07-2005 13:29
Well, I'd just tell Scotty to disengage the warp engines and go sub-light :)
Parent - By CHGuilford (****) Date 01-07-2005 14:30
Lincoln Electric publishes many books that address weld distortion control. Their "Procedure Handbook for Arc Welding" has a bit on the subject. Cost is about $20. Check with your welding supply store to see if they have it. If the price is much over $20, I would order it online.
Chet Guilford
