Try not stopping without a short pause to fill the crater. When you stop abruply the crater pool is shallow and could induce crater cracks and thats very common. However not visually appealing, crater cracks are usually acceptable provided the crack does not probigate outside the crater. Also could try a run off tab????
I would like to recommend two points;
1) Equipment point of view
Genenally, FCAW or GMAW have a function of crater filling to avoid crater cracking by using low current and filling the crater.
SAW does not have this kind of function and seems to sensitive to crater cracking.
If your FCAW welding machines does not have this function, it is also sensitive to crater cracking. Try one with crater filling function.
2) Metallurgical point of view(Ferrite content)
If you use saw with 309L, I expect very little delta ferrite due to high dilution(refer to Schaffler diagram).
Subsequent welding with 308L could show very small amount of delta ferrite due to 1st bead.
You can choose welding consumables which show higher ferrite content as possible.
Any method which can reduce dilution will help.
(Low current, small diameter, weaving, push angle)
Delta ferrite content also depends on welding condtions. Please check your weldment.
312(L) may be a substitute for 309L.
If you want use higher welding current with SAW for productivity, 312 which has much higher Cr content can help you with much more ferrite.
