Up Topic Welding Industry / General Welding Discussion / weight of channel steel
- - By leon phelps (**) Date 01-10-2005 02:33
Hello,
I am fabricating a bracket using 5" channel. Is there a guide to tell me what this weighs per linear foot?
Thanks.
Parent - By pipewelder_1999 (****) Date 01-10-2005 03:13
Channel is specified by a size and weight per foot. There are various weights for each size of channel. You could measure the cross sectional area of the channel x length x .2833 to get the total weight.
Have a nice day
Gerald Austin
Parent - By R. Johnson (**) Date 01-10-2005 12:56
Besides the rolled channel shapes that Gerald refers to, there are also channels that are manufactured out of sheet or plate material. These shapes usually have a radius on the heel of the channel and are a uniform thickness throughout.
If what you have is a hot rolled shape, my Ryerson book shows two weights for a 5" channel, one at 6.7 lbs per foot and the other at 9.0 lbs per foot. Also be aware there are MC channels or sometimes called ship channels that have different weights and dimensions. Luckily they do not come in a 5" size. Hope this helps.
Parent - - By LarryL (**) Date 01-10-2005 15:23
The Engineers Edge website has a lot of useful tables and data on a number of engineering subjects. This page leads you to tables for various structural steel shapes:
http://www.engineersedge.com/structural_shapes_menu.shtml
Cross sectional areas are given in the tables for each standard size of structural steel shape.
Parent - By Sand Man (**) Date 01-11-2005 01:40
Leon ,
Nice to see you back.
Standard 5"x1 3/4 x.190 structural channel is 6.7 lbs/ft, and
5"x 1-7/8 x .325 is 9.0 lbs/ft.
hope this helps, Jeff
Parent - By G.S.Crisi (****) Date 01-11-2005 13:45
Any engineering manual has lot of tables showing the weights of all kinds of structural steel.
