Sorry:
This topic has been discussed previously in the Forum. I respectfully disagree with both of the above replies (but somewhat agree with Tim).
I interprete the D1.3 code as follows:
1.) Table 1.1 of the D1.3 code, Note 1: Low hydrogen electrodes shall be used when required by ANSI/AWS D1.1." This note is applicable to all Matching Filler Metal Requirments.
2.) The provision noted by Michael in 1.4.2 requires approval of the Engineer, not the contractor or the inspector. Undermatching is very common, for the Engineer...
We regularly require lo-hi here in So-Cal for arc spot welds when decking is attached to A 992, A 572 Gr. 50 or any other material listed in D1.1 as requiring a lo-hi filler metal.
