If you would of taken off the covers off the pipe pro and a lincoln sa welder, it would be a no brainer which would be more reliable.... I wouldnt want to be at the mercy of a thousand transistors, capacitors, and chips....... life expectancy of a pipe pro should be that of a television.. Miller is a good american company, but people seem to forget nowdays that simpler is more reliable....
