MB Sims,
I appreciate your concerns and agree with the majority of your statement but take issue with certain comments.
Firstly,
" taking technical info from an unknown internet source as being sound technical advice." I took that information verbatim from AWS and API publications sitting in front of me.
Secondly,
I have spent 12 years as a CWI with a lot of this time involved in third world countries ( Papua New Guinea, Fiji, Vanuatu, Kiribati and the Solomon Islands).Some of the stories regarding quality control (or lack of) I could tell you would make you cringe.
Dodgy work has been happening for years (and not just third world countries) and will continue to happen in the future.
There is a possibility that 6010s have been used in the past for welding this material and the consequences (worst case scenario) could prove to be catastrophic.
I think this gentleman has already made "the lives of workers and surrounding neighbourhoods "safer by actually asking the question and not just going ahead and welding with whatever they found the most convenient.
Believe me, it does happen!
Regards,
Shane Feder
As Sim said, "If CS weld metal is used, there will be carbon migration from the weld metal to the 9Cr side of the joint during PWHT". So for high temprature, more than 400C I think, a nickle base alloy filler must be used, not to let carbon migration.
Ali, may you tell us ASTM designation of your carbon and 9%Cr steels?
