Hello,
I have a welder qualification issue. I need to qualify several welders to weld thread-o-let type connection to 1 1/2" sch. 80 pipe branch. The thread-o-lets range from .250" to 1.125" in diamenter and have approx. a .0625", 30 deg. bevel (chamfer) on them. They are combination single bevel / fillet welds (.250" fillet) with full root penetration (there will be .0625" root opening) is required using a combination of GMAW for the root and FCAW for the finished weld (fillet). My question(s) is, what type of test will be required to qualify theses people? Will they need to take more that one test because of the various diameters. And what type of testing is required for to qualify the procedure especially for the smaller diameter of pipe / tubing (.250")? All welding should conform to ASME B31.5 Standard Piping Code which refers to ASME Section IX.
My objective is to minimize the amount of testing needed. Any thoughts?
Thanks for any help ,
Chas Miller
