![](/mwf/attachments//avatars/4269-2369.jpg)
Lawrence is correct about certain types of wire, but that shouldn't stop you from using your small wire welder, simply purchase a spool of self-shielding fluxcore wire that WILL allow multi-pass welding. However when you add the gas bottle/regulator, your choices of wire are larger to choose from.
John wright
