Hi Vik 1. Am I correct in assuming that the brazing filler metal is a nickel base brazing filler metal?? If not what is it??
2. If nickel brazing filler metal I would suggest using a T specimen. two variables of the test must be separated. a) the brazing atmosphere and b) the flow properties of the filler metal.
To separate these two, each lot of the specific filler metal must be tested along with a standard lot that is used for all test of the same brazing filler metal - when the standard is identical each test, then the variable results are caused by the filler metal. The filler metal with a cement and powderer is placed on one side at one end of the inverted specimen.
The indicator of the results is the residue of the filler metal left at the point of application after the brazing cycle. Some filler metals are more fluid and have a narrow melting range, others that have wide melting ranges have a tendency to leave a residue. Part I
