Up Topic Welding Industry / Technical Discussions / Help to find material
- - By - Date 02-03-2005 13:04
Hello`
I have this material ASME SA516 Gr 70.
We have to make a WPQR for this, and need a litle piece that has to be 200mm thick.
Is there anyone that can help me. We are in Norway
Thank You
Parent - - By chall (***) Date 02-04-2005 15:25
That is a very common material and has a UNS number of:
K02700
From CASTI Metals Black Book it cross references to the following numbers:
1.0481, DIN P295GH or 17Mn4, UK - BS 1501 Gr. 224, France - NF A 48 & AP, Russia - GOST 14G2.
Hopefully something above will help you procure the material close to where you are.
Charles Hall
Parent - - By - Date 02-07-2005 08:02
Dear Charles
Thank You for the help, I will check this today.
Have a nice day
Parent - By G.S.Crisi (****) Date 02-14-2005 23:33
3115,
are you sure the piece you'll have to weld has a thickness of 200 millimeters (about 8 inches)?
That's a tremendous thickness! What are you going to make, a nuclear reactor?
Are you sure you didn't mix up thickness with length or width?
