We use the Goodman diagram for castings and forgings.
The main point as I understand it is the Goodman approach reduces the
allowable stress amplitude Sa in proportion to the mean stress Sm, when Sm is tensile.
In other words it recognizes that in tension, the Sm does have an effect on Sa and Sr, and it should be reduced.
In the case of AWS D1.1 "A" plate for example, Sr is 24 ksi so Sa is 12 ksi.
If an Sm of 25.5 is applied, then the Sa must be reduced from 12 ksi to 7.62 ksi. if you apply a Goodamn diagram.
I guess this is where I confess I have not seen in the AWS where Sm is
addressed like this.
Basically the AWS S-N curves are for Sr = 2 Sa, which always has Sm < or = Sa built into the curves, yes?
So this would take care of any loading that went from 0 to peak and back down, much like in bridge loading, or any harmonic load where Sm = 0, yes?
So now I am wondering what do we do with loads where Sm > Sa ?, and Sm is tensile, in a design we are working on.
Is this the point where we start applying some double modified Goodman rule for weldments?
Is there any one out there applying Goodman diagrams like this to welded designs, when Sm>Sa?
