Up Topic Welding Industry / Technical Discussions / Alternative fuel through Oxy-Acety rig..
- - By jyardblacksmith Date 02-07-2005 04:31
Need to know if I can run propane/natural-gas/mapp/propylene through my Oxy-Acetylene rig without changing anything other than the tips. I've checked the manual and it doesn't have any info on this.
Do I need a new regulator/hose/ect to run these alternative fuels, or can I use what I already have?
I do a lot of metal forming, and some glass forming and would like to have the option of using propane since it's a bit more mild than acetylene.
Help a greenhorn welder out!
Thanks.
Parent - - By 357max (***) Date 02-07-2005 14:19
Call the torch and gauge manufacturer with the model number. They will have the correct answer. Different materials for seats and seals reacts to different gases. The hoses should be okay.
Parent - - By sparx (**) Date 02-08-2005 13:23
Actually, the only thing you need to replace (other than tips) is the hose. standard R grade hose is designed for acetylene only. you will need to run T grade hose (will say on the packaging -for alternate fuels) the rubber lining in the fuel hose deteriorates from the addatives in alternate fuels.
Parent - By Lawrence (*****) Date 02-08-2005 16:31
Just to be perfectly clear on this tricky subject.
Grade R-RM fuel gas hoses are for acetylene only.
http://www.parker.com/ead/cm2.asp?cmid=3782
Grade T fuel gas hoses can be used with Acetylene, Mapp, Propylene, Hydrogen, Propane and natural gas.
http://www.parker.com/ead/cm2.asp?cmid=3757
Check and see what you currently have.
Parent - By jyardblacksmith Date 02-08-2005 21:00
Thanks fellas. I'm going over what you guys have told me, and I'll get back to you after I get it figured out.
