Up Topic Welders and Inspectors / Welding Equipment Classifieds / Lincoln SAM-400
- - By Sand Man (**) Date 02-07-2005 12:20
For Sale,
Lincoln SAM-400 F245 CC/CV welder code 7800
400 amps@ 40 volts 60% duty cycle
Internal contactor,120v ac aux,Remote amp-volt control,auto idle conrol, High idle switch- no need to pin throttle.
6cyl continental gasoline engine, runs and welds very well.
Parent - - By slag_pocket_dan (*) Date 02-26-2005 03:29
I am really interested in your machine. can you tell me the approx. age and where in sd you are? also what is the price and is it firm or not so? at about 130 amp or maybe enuf to run 1/8 rod and 3/32 lo,hy is the machine 100% duty cycle? thanks dan
slagpocketdan@yahoo.com
Parent - - By Sand Man (**) Date 02-26-2005 04:49
Dan,
I think it is a 1979 model .I bought it in 1983 in Gillette, Wyo.
This machine is rated 400amps @60%. You can air arc with 3/8 carbon and it doesn't seem to be working hard. It is a 2400lb unit.
I am located in N.E. SD asking $ 2000.00
Jeff
Parent - - By slag_pocket_dan (*) Date 02-26-2005 19:00
i have a daughter and family near watertown more exact, south shore
if you dont mind, and they are close enuf to you, mind some pics taken or will you take several foto's af the machine and e-mail to me?
what is the serial num and code num? thanks dan
Parent - - By Sand Man (**) Date 02-26-2005 23:31
Dan,
S/N A-855350 Code7800
I emailed some pictures earlier, but my email is acting weird, so I don't know if they went through.
Parent - - By slag_pocket_dan (*) Date 02-27-2005 13:32
they went threw ok nice machine
Parent - - By Sand Man (**) Date 02-27-2005 15:31
Ihave a few more pictures if you want them.
Jeff
Parent - - By slag_pocket_dan (*) Date 02-27-2005 18:28
sure it is a long way to ne sd from kc ks
Parent - - By Sand Man (**) Date 02-27-2005 19:08
Yes it is, 560 miles. but if you need a sam 400, they are hard to find.
Parent - - By slag_pocket_dan (*) Date 02-28-2005 23:45
how many hours are on the welder, engine?
Parent - - By Sand Man (**) Date 03-01-2005 12:42
I don't know, it never had a hour meter. It runs smooth, welds good, all the controls work. it has been very well maintained.
The only reason it isn't still on my truck is I needed to lose weight.
I still sometimes miss the extra capacity, and the quiet machine.
Parent - - By slag_pocket_dan (*) Date 03-11-2005 01:38
i am going to the bank tomorrow and beg for some cash to buy your machine i needed to do some home work on the sam400 one last question, under a load of say yor carbon rods, how long does it take to burn a tank of gas? thanks dan
Parent - By Sand Man (**) Date 03-11-2005 01:59
Dan,
if you are welding 1/8 7018, you can run about 12 hours, more or less.
Doing heavy work, 8-10 hrs. 20 gallon tank.
Jeff
Parent - - By GREENS Date 03-08-2005 02:42
If you still have this welder I am interested in buying it....
How much are you asking.
Patrick
Parent - By Sand Man (**) Date 03-08-2005 02:46
Patrick,
I have it priced at $2000.00
Jeff
