Hi Mechengdaw -
I do not know ao a solution that will test the cladding. Possibly the manufacturer might.
I would suggest having the surface be spectrographically analyzed to determine the % of silicon and any other major elements such as Cu etc.
If the filler metal is BAlS-4 (4047) it should have 11-13% silicon, bal. aluminum. There will be small amounts of Mg, Cu, and Mn.
