ok, well setting the amps is more set by foot control while watching the puddle, I just turn the knob and go from there. Most important thing about Aluminum is the prep cleaning. Aluminum melts at 1200 and the oxides melt off at 3600. The cleaning is the + side of the AC sine wave and the penatration is the - side. Preflow could be set at 5 seconds and postflow is ruled at 1 second per 10amps. Tungsten size could vary maybe from 3/32 to 1/8 depending on material. 3/32, 70-100Amps. 1/8, 100-150Amps. Your tungsten tip is 1-1.5 of diameter *Hemi-spherical ball* . Cup size is 2-2.5 times electrode. GL
Brian
In regards to welding anodized aluminum. Amperage should be set at 250 on AC,1/8th green tungsten, I prefer pure with the ball. 5356 filler rod.I also use pure argon gas.I use a snap switch on the torch body. No foot pedal. On/Off pulses welding in reverse travel.This keeps gas right on the puddle. No,this isnt regular specified welding but this works best for anodized. The anodized coating will float to the top of the weld and crystalize. If done correctly,Anodized welds will weld alot easier than mill finish and look alot nicer as well.You dont have to clean the joint area unless you are doing x-ray certifiable welds. The weld will exceed the strength of the parent metal. The welds then need to be painted with aluminum rustoleum paint. Altho the welding crazes the surrounding anodized coating slightly,it doesnt sacrifice it's corrosion protection.Especially if you wipe the item regularly with a rag sprayed with corrosion blocker as a part of it's maintenence.If you would like to see some projects constructed of anodized pipe you can look at my personal website at www.home.earthlink.net/~tigmaster41/ on the aluminum outfitters tab. This is not a sales site.
One other note: I used to make much prettier welds on anodized pipe with the Miller Aircrafter machines. Have yet to meet a synchrowave to match those welds and the ease of which it welded them. Not to mention how noisy the square wave machines are on AC.
